I've been reading these boards for a while but its my first time actually posting. I've done searches on wiring things directly to the battery but I'm not completely sure about a few things. My friend has seen what I've done with neon lights to my car and he wanted me to add one to his trunk on his lexus. Problem is that I've never wired anything directly to the battery before. I don't want his car blowing up or catching fire or anything so I figured I should see if anyone here can help. I found a path where I can run the wires to under his hood but I'm not sure about the whole fuse deal. The light he has is that 10" neon tube from walmart and the wire is really thin. I was wondering if it was safe to connect this directly to the battery? Also what type of fuse would I need to use?
Another thing thats been bugging me is grounding stuff. I read somewhere that you shouldnt run your ground wire to the negative terminal of the battery and I was wondering if that was true.
Anyways thanks for taking the time to read this and hopefully someone can answer my questions.
