9Shenandoah
- 99 Mazda Protege 1.6 5 speed
What's the correct fule pressure on a 2000 Protege 1.6 L ZM engine? Even the shop manual is confusing. In one place it says 36 to 40 psi and in another place, it says 40 to 45 psi.
Fuel Pressure Specification - W/O Vacuum: 38-45 psi (2.7-3.2 kg/cm2)
W/ Vacuum: 30-36 psi (21.-2.6 kg/cm2)
If you do not know the proper procedure, let me know and I will post it.
