IMO, those gauge rings are the best aesthetic interior mod for the P5! It hurt me to remove mine, even though I was trading the P5 in. lol
Looking forward to installing them. Wondering if there is a video/image link for the gauge cluster removal, and access to the gauges/bulbs?
This thread, like my Protege5, is starting to feel like it's reaching end-of-life. In an effort to keep both alive in their own ways, here's what's been happening in my garage of Proteges.
P5 hit a fun milestone
Long list of growing todos. As you can see, correct cluster bulbs are on the list. Also replacing my rear strut (broken swaybar mount from the beefy swaybar), removing old tint, fixing broken drivers seat, hood paint peeling, etc. etc. Still daily driving but she's a beater. Smokes on startup now. Front suspension is also sounding awful after installing whiteline poly bushings...something is wrong, or loose. Looked underneath and looks all good, so I'm confused.
My auto ES Sedan was the free backup beater for the daily beater lol. Currently sitting on my Mazda3 wheels with Blizzaks from my P5. Been doing some work on it to clean it up.
It sat for like a month while I tried to replace a siezed axle that was making an obnoxious clicking noise. The axle was stuck in the hub. Ended up getting a used spindle/hub and putting a new axle in. After all of that, still makes the clicking noise. Guessing it's the diff or a trans bearing. Car just hit 230k, runs and drives well. I just ignore the noise now.
Sedan will get sold as soon as I don't have to depend on the P5. Hoping to keep the P5 around as the fun beater project but if the engine goes it may not make sense to keep it alive.
Anyways, these cars are kind of a pain at this point but they don't break down, that's for sure. I just keep putting miles on em.
Replaced both broken side mirrors with new aftermarket units. Had to de-pin the tweeters from the original mirrors- which was odd considering how the two wires going to the speaker have their own connector further up the line. Passenger mirror works, but the driver's side is dead on arrival, so I'll need to either return it, or open it up to see what the problem is.
After scrounging all the local junkyards and "u-pull it" yards in the area, I decided to bite the bullet and ordered a replacement fender and bumper from Partify. They offer a "painted" option, and for the price ($245 painted and shipped for the fender), I figure it's worth the risk...
Put these in a few days ago. Blue LEDs for a consistent look. Also gutted second (only one now) cat, allowing less restriction in the "almost" stock exhaust. Pile on floor is what's left of the catalyst.
I'm doing the same as you with header to the stick exhaust albeit sans cat guts.
Let me know how you like it and how it changed the driveability of the car as well.
Are you running OEM muffler?
How's the tone now?
How's the tone now?
Car seems to have gained a very slight bit in torque as it's seat of the pants feel is that it pulls easier up through the gears and higher RPMs seem to be attained more fluidly. The resonator behind the second cat gained a small "resonance" (vibration) at 3500 RPM, but mostly when cold and I don't hang out at that point long. Will most likely go away if I put a cat-back system on.
Good to know and thanks.
That's exactly what I'm seeking with my Protege.
Nothing noisy, not racing, but a sweet running car setup for longevity. 👍
This car is amazing but if you don't take good care of it, getting it back working on the road is a pain.
I'm having corrosion in the right passenger floor, all that humidity fried my PCM I got a new one but the troubleshooting to find out took me a lot of money and time and stress. Now it seems that water is also starting to appear in the driver side :)
Anyway, recently had to repair my steering box, much cheaper than a new one, but let's see how long it last. Also had to replace the return line cause it was leaking, I think it was the original one so not bad.
Now I'm trying to get the AC running after many years, it worked for a few weeks then leak, new evap, now the AD fan is dead (maybe original too), new fan installed, but the compressor doesn't engange unless I ground the AC pressure switch, so maybe a new leak or bad switch.
YES! Would not have bought one without the 5 speed. Now if it only had a 6 speed and a 2.3 Speed motor. This will do though.
It's been a long while since I had posted anything of substance. I decided to finally attack the rear main seal replacement job. I added in several other "while I'm here" things to that list.
Rear main seal, clutch replacement, oil pan reseal, plugs, wires, oil change, trans oil change, axle rebuilds, valve cover gaskets, etc, etc.
For having 225k miles on it, my OE clutch was in great condition. I'm sure it could have lasted many more miles with my driving habits. Either way, everything is completed and the Mazda made it back to being my daily transportation this morning without complaint. There are still a couple of very minor things that I want to do before I put a bow on this and call it done, but I'll likely take a weekend off before getting back to it.
I also finally got the pinch weld pucks that I've been wanting for my lift. I know that there are varying opinions on their usefulness. Either way, I have some now and use them to prevent damage to my lifting points.
