What gas do ya use???
Rider69 said:
Here is from the manual:
Vehicle damage and drivability problems resulting from the use of the following may not be covered by the Mazda warranty.
Gasohol containing more than 10% ethanol.
Gasoline or gasohol containing methanol.
Leaded fuel or leaded gasohol.
Fuel Requirements
Fuel Octane Rating* (Anti-knock index)
Regular unleaded fuel 87 [ (R+M)/2 method] or above (91 RON or above)
USE ONLY UNLEADED FUEL.
Your vehicle can only use oxygenated fuels containing no more than 10% ethanol by volume. Damage to your vehicle may occur when ethanol exceeds this recommendation, or if the gasoline contains any methanol. Stop using gasohol of any kind if your vehicle engine is performing poorly.
Never add fuel system additives. Never add cleaning agents other than those specified by Mazda. Other cleaning agents and additives may damage the system. Consult an Authorized Mazda Dealer.
Muchas Gracias. I forgot to look (funny me)......:D
uclap5 said:
exxon - 87. cheapest near me... which is $1.80, which is good since it was up to $2.15 at the cheapest a few months ago.
Oil companies have reported the largest profits ever the past two years. Use fear of a war and a shortage to raise prices for no reason.
F***ing gougers....
F***ing gougers....
no doubt.
after 9/11 the chevron near me had gas at $5 a gallon. and it was packed with people. good thing people wised up and prices went down.
JunkPunch said:
There is NO POINT whatsoever in using anything other that 87 gas in your P5, UNLESS you have a turbo. None. There is no benefit at all. If it makes you feel better to waste your money, go nuts, but you aren't getting anything from it.
I agree. 87.
