Water Neck / Thermostat Housing Cap
thepope540
2003.5 Yellow Speed - Sold, Spicy - Sold, #639 Black Mica
If someone has a spare that they can take a couple dimension off of I would much appreciate it. I need to know the ID, OD, and bolt spacing. I have the first round of thermostat housing spacers coming in this week and now I'm not sure if the housing gasket I used is from an FS or KL. If you can help me out with dimensions I will give you a small discount on buying a spacer. I would do more, but my margins are really small on these. Thanks guys!
Tom
I just removed my stock one today to install a straight water neck so I can get them for you.
Yes, but it turns out that I have multiple gaskets on the shelf with no part numbers and I'm not sure which is which.
STANT Part # 25285 More Information About this Part {#27285} 1 15/16" x 2 7/32" x 7/32" (Grooved, Molded)
Right from rockauto.com
Thats the rubber o-ring style gasket that actually fits on the rim of the thermostat. I have a couple paper style gaskets that are the profile of the water neck, but now I'm not sure which is for the FS and which is for the KL. I would just check, but right now I don't have a car with either engine. I'm picking up a spicy, but it doesn't have an engine or trans at all and I sold my blazing last fall. I'm looking forward to getting another msp up and running so I have a test bed / showpiece.
Sorry for the delay, for the thermostat housing on the block the ID is 1 29/32", OD is 2 21/32", and the bolt holes center to center are 2 12/32".
