unfortunatly...
Dr0
03 Black Mica MSP
My wg is now pretty much siezed idk if its open or closed... I think its partially open bc I still get some boost but its pretty much a tiny taste followed by a lot of loud whooshing sounds and me not moving any faster :/
Basically is it cool to drive like this for a while?
And what are my solutions to fix this?
I know I can get a replacement housing I just don't have any clue where
Any help would be great
It sucks knowing I have my exhaust set up ready to bolt on and this happens... Blah
Awsome I read a post before about doing this fix but it also involved heating it up and pounding a tap around the wg housing to hold that sleeve and not let it back out again.
Bc if its worn enough to move it can and will prob move back with time
And one more thing what did you need gasket/materials wise? I prob will end up doing this fix, I miss boost so much :(
easiest to take the whole thing out youl need 4 gaskets if you take the whole thing apart..
but thats only if you take it all apart..you dont have to take the mani and turbo apart but it will be easier to handle and clean if you do. My turbo is holding up good spools quickly i have had no other issue since that point..
