Turn Squeak
sprinter119
2013 Mazdaspeed3
Lately my car makes a squeaking noise when i turn the wheel and sometimes while im just rolling slowly. My belts are tight my next thought would be my endlinks are making noises. The car has been lowered for about 60000 miles on Teins with stock components. The squeak is like something is rusty would be the best way to explain. Thoughts?
Noooooooooooo.... Last time i took my car to a mechanic they wanted to charge me extra per hour since i had a lot of modifications done to it. Ill take a look at this weekend.
Wow i have the same problem. its every now and then. It sounds like a sqeaky door or a squeaky spring in a bed. How bad is this problem?
EDIT: Car has stock suspension. Nothing modded
it'll get worse as time goes on. it's a bearing. i had the exact same noise, replaced bearings, all fixed!
I think i have the same problem. I thought it could also be my calipers that are jammed or stg. And i know its comming from the back but im not sure if which wheel or if the front ones do that too...
easiest way to check front bearings, jack up the front of the car, wiggle the tire left and right, up and down.. if the bearings are bad, you will know it. there'll be excessive play in them.
Bump
Question.
I was looking for the part on rockauto.com and i am not quite sure what i have to buy. The sound got worse and tonight i was rolling at around 5-10mph and it was LOUD like a non-oiled door hinge. Am i suppost to buy the Knuckle Support?
This is the stock knuckle support # 45K18035
This is and aftermarket Knuckle support # 45K18047
Any help would be appreciated :)
heh when my honda squeaked while turning it ended u being a shot power steering pump. hope you get your stuff fixed
Or is it the steering column (thye joints under the hood? WD-40 'em see if that fixes it... (if the bearings checked good)
