Hi Folks,
I have a 2001 2.0 FS engine premacy with the FN4A-el transmission.
the transmission is causing me some grief, I have repaired it once myself but... it only worked great for a few days.
So the area's that I didn't get involve in when I first took it apart are related to replacing all the bushings. Which without a means to measure them seemed okay and it takes me 5-6 weeks to get parts I can't find them here or at a price I want to afford (like $1500 for a used transmission with no warranty/and not history)
Currently reverse works all the time, codes are related to incorrect ratio (slipping in d). once warmed up everything works. and cold here is +24C.
I just took the valve body out which is fine and rechecked all the solenoids also good, Transmission shifts correctly - no load wheels in the air.
I would like to check the transmission fluid pressure however I have so far been unable to locate a gauge to use
Previously I replaced the (pistons, seals, friction discs and steels), 2-4 brake band, installed rebuilt solenoids, and a shift correction kit (why not).
I am currently planning to order a set of bushings, another seal kit, a selection of shims, C clips, strut bolt re proper clearances (none of which are available or known about locally) a ford end cover/adapter, connection tube solution
and a transmission gauge which I hope I don't need (as that would mean the pump is shot...)
Well if your still here, thanks your advice is welcomed
Thanks and have a great day.
