There's a TSB our on the roof rack noise. The dealer should fix it for free...
NOISE FROM ROOF RACK CROSS BARS
Applicable Models
Model Starting S/N Ending S/N
2002 PROTEGE 00000000 ZZZZZZZZ
Some customers may experience a resonances and/or a whistle that is generated by the roof rack cross bars, these noises will vary according to vehicle speed and wind speeds.
Although the wind turbulence noise generated by the roof rack cross bars should be considered normal, Mazda realizes that some noises are an annoyance to some customers. Improvements were made to the front cross bar to reduce a resonance that occurs at approximately 35- 40 MPH by adding additional wind checks to the face of the cross bar. The lower edge of the bottom wind check that runs the length of the cross bar was trimmed to eliminate whistling.
Order improved cross bar through MNAO Parts Dept. Please confirm that the cross bar(s) are installed with the wind trips (sharp edges) pointed to the front of the vehicle.
Part Information: Cross Bar - BN6B-51-6A8
