Speed6 Foglight bulb install??
VRMS6
2011 Kona Blue Ford Edge Sport
I hate the look of the stock fog lights yellow color so I ordered a set of XenonMatch bulbs from HOEN. I had them on my MZ3 and they matched the HIDs nicely.
Im looking to see in anyone has instructions on R&R the fog light bulbs on a MazdaSpeed6. I could probably figure it out without instructions but I prefer knowing what Im taking apart before I do so... Any help is appreciated...
searched "fog light bulbs" but nothing relevent showed up... Knew of HOEN from my previous ride so didnt look in that thread.... Thanks for the links...
Jack up the car and place on jack stands.
Take the under panel off. It has a few screws and rivets,
Drivers side is easy as all you have to do is remove the bulb and replace it. Forgot which way to turn to make it loose but its easy.
Passenger side, I took the two horns off for easy access because there was too many things down there(resevoir..etc..etc..)
Voila, there you have it.
No need to search my friend, this is too easy for you to even waste time searching.
hope this helps
yea looking at the links provided it appears to be easy as pie. I work at a car dealer so a lift will make things much easier than jackstands....
ordered hoen's friday and came today. installed them and they look good. took like 10min to put them in. having the cobb intake left room to change the driver side one from in the engine bay. for the passenger side i just took out those 4 bolts, took at the horn (1 bolt) then took at the light.
can you post night time pics after install? i just bought my spd6 yesterday and would definately like the fogs to match the hids
Since nobody else is posting theirs, I took a pic of mine.
Anybody else? (pics)
i'll try and take a picture of mine later. you should replace those lights closest to the grille with some that match. I did and it looks better.
RedBli$$ theyre just the factory bulb replacements....
Shaqgate Havent had the time to do the install will probably get it done tonite... BTW did I mention I have access to every tool known to man for car repairs...Including AIR TOOLS.... :)
KILLER thanks for that bit of info I should be 100% able to install these now...;)
Actually, I replaced the stock white ones with yellow (crappy cameraphone). I like to be a little different... (2thumbs)
I've also replaced all the other lights on the car with white LEDs. I get a lot of compliments on the interior lights.
Shagate Havent had the time to do the install will probably get it done tonite...
Yeah, yeah... While you figure out how to change a light bulb I'm going to install a Mazda alarm shock sensor. Bet I'll finish before you. (rofl2)
No you neglected to mention that. (gun)
(chair)
(eekfu)
