So i got my boost gauge installed.....
.... when the boost kicks in the needle pops up to about 5psi and then falls right off to nothing! Is this normal? :wtf:
no, if you have your foot on the gas the boost shouild stay up there.
Well
That is exactly what mine did stock only 5 PSI then drop.
Now with my JoeP MBC it goes to 12 then stays at 10 until I shift.
no, he said it falls to nothing...
mazdadryvr,, just go back and check the fittings on the boost gauge.. see if you connected everything right.. if its a autometer, I know the connections on the back of the gauge can be a b**** to figure out... also, go back and check where you tapped in to the vacuum line.. make sure everything is tight and secure
check the T fitting and make sure there is no crimping in your vacuum line.
did you use the vacuum line it came with(nylon) or replace it with a rubber tubing? check where the vacuum line goes through the firewall and see if the tube is crimped.
the T fitting might be where its at though..
oh and what vacuum line did you go into?
after some further testing i have found that it behaves differently in each gear. I had only tried it in low gears so on the way home tonite I spooled 'er out good on the highway and found that it stays in boost better in the higher gears. It goes right to 5.5 and stays there until I back off on the throttle. Whew! I was worried there for abit. :)
Im glad you figured it out on your own. My MSP hits about 7 in 1st, then falls to about 5.5, 7 in 2nd, holds at about 6, and holds 7 in 3rd 4th 5th.
Soon to be holding at 10.
Wheres my darn MBC!?!
well it never went past 5.5 at anytime.
I am going to drive it around for a few weeks before I put my JoeP MBC on it(and FPR) just to see how she performs stock.
:cool:
