KrankVents installed. Everything seems to be working well. My vac has increased by 1-3 in/HG after the install. No change in temps according to the Mac Tools Taskmaster scanner. Only time will tell how these will work out.
As I understand it, the pcv side KV prevents boost pressure from entering through the pcv valve without interfering with the pcv's vac supply. The stock and even the SC Millenia pcv will not hold much boost pressure. I tested my Millenia pcv with a pressure pump and it began allowing pressure to pass through at about 8-9 psi. I'm sure the stock pcv is worse. By allowing pressure to enter through the pcv, more pressure is built up in the crankcase causing increased possibility of oil/vapors blowing by the piston rings and being burnt during combustion. This same pressure can also cause an increased amount of oil/vapors to be blown out of the crankcase breather tube and into the intake (if the crankcase breather is in stock form, if you are using a breather filter the oil/vapors gets blown into the filter and/or engine bay). The pcv-side KV will hold more pressure (without leaking) than my pressure pump would generate, so this part of the problem should be solved.
The breather tube side KV is designed to allow high pressure pulses to escape the crankcase, however it prevents air from entering the valve cover through the breather tube. The reasoning behind this valve is that it will increase and maintain crankcase vacuum. Higher vacuum means that more (harmful) vapors will be drawn from the crankcase at a faster rate, thereby further reducing the possibility of blow by.
Although I have not tested this theory, it seems that with increased vacuum, there is also an increased chance of oil being sucked up through the pcv valve. For this reason I believe that it would be a good idea to install a catch can between the pcv and the pcv-side KV. With that combination, I think that oil consumption would be virtually nonextistent. I have a catch can ordered and will let you guys know the results when I get a chance to test my theory.
