OK, I sent an e-mail to NGK about our setup and running at 10psi. My e-mail is at the top, with his responce at the bottom. I hope this helps in our search for the "perfect plug"!
My e-mail:
"Hello, I have a 2003 MAZDASPEED Protege, and I didnt see anything for that in your "part finder" section for this car. It is a 2.0L DOHC Turbo charged (T-25 Garret running at 10psi). It has platinum NGK PZFR6F plugs in it now (stock). I would like to go with colder plugs (1 range colder). What would be the best plug # for this? I think that the stock plugs are just the wrong type of metal, and the wrong heat range for 10psi boost. I was told that the Copper NGK BKR7E-11 would be better for this setup. Those
particular copper plugs have a wide tip, unlike the iridium, wich are thinner. Wouldn't the iridium ones be better in preventing detonation than a wide tipped copper plug?"
His responce:
"All of our spark plugs have copper cores. The PZFR6F is a double platinum spark plug. I would suggest dropping one heat range and use the BKR7EIX-11. The fine wire is helps improve ignitability. Also it's important to remember the higher the cylinder pressure the more required voltage is needed to fire the spark plug. This means you will reduce gap with boost increases.
Jon MacQuarrie
Technical Customer Service Representative
jmacquarrie@ngksparkplugs.com"
My e-mail:
His responce:
Jon MacQuarrie
