Peugeot 5008 to Debut at Frankfurt in September 09
coolmazda5
Contributor
2008 Mazda5 5MT Sport w/ Popular Package
Hot on the heels of the debut of the production version of its 3008 hatchback at Geneva, Peugeot is striking again with an upsized version called the 5008. The seven-passenger, minivan-like 5008 will debut at the Frankfurt Motor Show in September.
Nearly the same size and shape as the Mazda5, the 5008 will come in five- and seven-seat versions offering loads of cargo room and plenty of technology. With the front passenger's seat folded flat and the second- and third-row seats folded into the floor, the 5008 will swallow up to 88.5 cubic feet of cargo. Additional storage space is available in the floor in front of the second-row seats when the seats are not folded and in the rear floor on five-passenger models. A cooled center console bin will hold more cargo and chill it if you wish.
If you're more inclined to haul people than boxes, Peugeot has you covered. An optional rear-seat entertainment system puts two 7-in. LCD screens in the backs of the front seat head rests that can accept two different video inputs at the same time, each playing on one screen. Sound is provided through a pair of Bluetooth headsets. Other onboard technologies include a heads-up display, a special snow and ice mode for the traction control, a Distance Alert system that warns the driver when he or she is following too close, stability control, six air bags including side curtain air bags, a tire pressure monitoring system, an electric parking brake, hill start assist, and a parking aid that measures the amount of space in front of or behind the vehicle and displays it on the multifunction screen along with a suggested parking maneuver.
Powering the 5008 will be a choice of either a 1.6L gas engine or a 2.0L diesel mill. The gas unit will make 110 hp and achieve 38 mpg to 40 mpg when equipped with a five-speed or a six-speed manual respectively. The diesel will make either 150 hp or 163 hp and mount to either a six-speed manual or six-speed automatic gearbox and return 48 mpg or 42 mpg respectively.
Source:
http://wot.motortrend.com/6545970/a...to-debut-at-frankfurt-in-september/index.html
Yea, the Mazda 5 was the first example of good looking people movers. :P I'd tap that though. Here's to more reasonably sized people movers to replace the monsters on the roads.
Specs:
Wheelbase 2735 mm (107.7 in)
Length 4530 mm (178.3 in)
Width 1835 mm (72.2 in)
Height 1640 mm (64.6 in)
Mazda5 Specs (to compare):
Wheelbase 2750 mm (108 in)
Length 181.5 in (4610 mm)
JDM: 177.4 in (4505 mm)
JDM S: 179.3 in (4554 mm)
Width 69.1 in (1755 mm)
Height 64.2 in (1631 mm)
JDM/Europe: 1665 mm (65.6 in)
