Perfect Power PRS8 Standalone
StuttersC said:
Nice job...
Did you try loading a basic map on the unit?
There is already a fuel map loaded on the PRS8 unit. The ignition, and the lamda maps are zeroed out.
Well lets puts some values in there and get to work!!!! We all want to see how she works!!
Little Beavis said:
NO, need more info NOW.
Are you threatening me?
<shirt pulled over top of head and both arms bent 90 degrees with hands up, palms forward>
Ooohhhh, you need some Tee Pee for your bunghole!!!!!!
Linux, hop to it man!!! We want to see how that beast runs, and how well those injectors work ,man!
Well I just finished entering in a few variables applicable to my car on the PRS8, and saved it to my computer. I know what outputs are assinged to my injectors and coils. I have a few more setting to set up.
Ok, I hooked tapped into the Air temp, Engine temp, and TPS wire. I definintelygot some signals from the temp sensor, and have some calibration to do. I had the PDA Dyno hooked in and saw the variances. Here is what in the follwing picture below:
make sure that the flux capicitor levels don't go higher than 10...I noticed in the attached image that it was close to 9.1. Also you may want to adjust your vtec settings to open a bit later. Oh...one more thing...the dithium crystal levels look low....you amy want to change that before you make anymore changes....
:) ....Linux things are looking good....when are you hoping to get things fully done (target date)?
how do you think it willbe to tune. The program in the screenshot looks really user friendly. do you forsee any problems?
