Parking Light Replacement.
kahmikahze
2006 Black Cherry Mazdaspeed 6
Hey guys.
I recently bought a couple of LED lights to replace the OEM amber (?) parking lights on my MS6. When referencing my owners manual, all they say is "take it to an authorized Mazda dealer".
Well, I don't wanna do that, obviously, so has anyone done this, and has it worked for anyone? Thanks!
It isn't that hard. Just pull out the oem ones and replace them with the LED ones. There should be something on top of where you see the parking light and just twist it and pull it out. Replace it and there you go.
like, how to access it, i guess is my biggest question. I just wish there was some online diagram to go and show me.
I've also been thinking of replacing the OEM amber ones with white ones... You don't have to remove the headlight correct? Just pop the hood and you should be able to twist/pull it out from the engine bay and pop in the new one?
it was slightly as easy as you said. Just pop off the oval backing and pull the right bulb.
the crappy part, is that all the room is so tight inside, so it's a PITA to replace/change them. Unfortunately, I gotta go that tomorrow, because the great state of North Dakota doesn't like blue lights on the front of cars that aren't for emergency purposes...
