Went to the dealer today to get a safety done as I am buying out the lease on my Mazda 5. Anyways they come back with the usual suspects as new tires on front, wheel alignment, front brake job and rear sliders seized and the park brake adjustment.
I declined the service for everything and decided to take care of everything myself except for the alignment, which I had done at a friends shop. The front brake pads/rotors and rear sliders were a piece of cake and the park brake lever adjustment as well once I dug around.
If you look at the center console directly behind the park brake lever, mine is in a little cubby hole next to rear top mounted drink holder you will see a little access door that can be pried open. Looking inside while the drivers seat is reclined a fair bit you will see a 10 mm nut on the lever assembly.
Using a long extension, deep 10 mm socket and a flashlight adjust the nut in a clockwise rotation until the lever starts to engage sooner in the throw. Once you are happy make sure your rear brakes aren't dragging and resecure the door and you are good to go.
5 mins and I was done. They wanted $50 at the dealer to adjust the lever.
Cheers and hope this help save someone else some money down the road.
