non abs drive shaft and hub installed on an abs mazda protege
zach88i
2001 mazda protege es 2.0 manual
I have it installed. It doesnt seem like im able to get brake pressure and there is a leak where the work was done on the front left side. Is the because of the swap? Should i bypass the censor from the abs?
It's because the brake line was treated poorly when moving the caliper and knuckle (damaged by the mechanic)
