NEMOC Random BS Thread
is this the photo you were looking for?
lol owned
Thanks a lot Josh. I think I know what I'm going to get now...
Off to the gym, hopefully work off some frustration! (spin)
OMG Chris that is hilarious!
Cute pics of the animals everybody!
Here's one of Nala and Peanut Butter my daughter took....don't have one of Budman here at work.
Yeah... I am a sucker for puppies... I want a beagle! Or a dalmation!
I have a beagle, and we used to have a dal, great dogs but they're very territorial, not too good with little kids.
Dalmatian + Bunny != Dalmabunny
Someone photoshop a Mike Harder onto the back of that rabbit and put some jello-shot residue around the dog's mouth so we can put it in the NEPOC Meet album.
that's not a dal, that's a spaniel of somesort...the other dog i have.
I'm busting out the Fuzz!
I would've take better pics of my cat this weekend but she's in heat so she's not the happiest kitty in the world.
here are mine:
well really the cat is mine, the dogs are family dogs, but we've had em for 7/8 years or so.
my pet:
not sure when this pic was taken. sometime over the past couple of weeks??????
In the spirit of cute animals and such I provide this picture. I have held one of these animals and it was awesome, but I leave you with this....
I'm sure many of you have read this before, just too damn funny.
DRILL PRESS:
A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted project which you had carefully set in the corner where nothing could get to it.
WIRE WHEEL:
Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, "Oh, s***!"
SKILL SAW:
A portable cutting tool used to make studs too short.
PLIERS:
Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
BELT SANDER:
An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
HACKSAW:
One of a family of cutting tools built on the Ouija board principle... It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS:
Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETYLENE TORCH:
Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race..
TABLE SAW:
A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK:
Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
BAND SAW:
A large stationary power saw primarily used by most shops to cut good aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge.
TWO-TON ENGINE HOIST:
A tool for testing the maximum tensile strength of everything you forgot to disconnect.
PHILLIPS SCREWDRIVER:
Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER:
A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws and butchering your palms.
PRY BAR:
A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER:
A tool used to make hoses too short.
HAMMER:
Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit.
UTILITY KNIFE:
Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use.
Son of a b*tch TOOL:
Any handy tool that you grab and throw across the garage while yelling "Son of a b****" at the top of your lungs.
