NEEDED: how to install a boost gauge in a ms3
Nutari
Contributor
2010 Mazdaspeed3
NEEDED: how to install a Turbo timer in a MS3
please? I bought a Autometer boost gauge.. it came with wiring but no vaccum tubing or anything. I need to know what to buy to get this thing working.
thank you!
next up.. a turbo timer.
check napa thats where i bought my vaccum lines for runing my boost gauge on my msp. they also got fittings if you need that would probably work or go to checkers and talk to cherry she would know also since she still has her turbo civic.
doh.. too late. I bought it from those 42draftdesigns guys.
only like $15. I just need to figure out how to install it now. Where to I tap to get a boost source?
one of the easiest ways is to tee off before the stock bov. thats what i did until i found someone had it at another place then i moved it.
Just make sure theres no leaks around the Tee. I ended up zip tieing all the rubber hoses to the vacuum lines/tee on mine. I'm shocked that the gauge didnt come with the line. Mine did back in 2003.
I bought it used. Can someone point out where to install it on this picture?
Yeah that line pointed out in the pic is the vacuum line to the bpv. It should do the trick. Just tee off that line and you're golden.
Dave
Dave
Thanks Dave!
got the boost gauge kit from 42 draft designs.
ok.. the tubing is really small. I dont think it goes where you guys thought it did.
first two are without the cover .
third is where I 'think' it should go
last is the difference between the tubing and where you guys said it should go..
