need wiring diagram for speed 6 alarm system for apexi tt install
mnthny4
MAZDASPEED 6 AWD
Trying to hook up a apexi tt to my 2006 speed 6 but i need wiring diagram for the alarm system ,cause as per install the alarm will not arm with tt working ,only got the alarm to arm with TT install fully after pulling the 15amp fuse for the METER IG in the fuse panel but note all my guage would not work but TT & alarm would work like it should ,so please if anyone can post the wiring diagram for the alarm system i may be able to solve all the speed 6 drivers problems with alarm function with TT INSTALLED. THANKS
Got the wiring info from all data ,it took me like 15 min to figure which wire to cut & re-route ,got alarm to work fully with TT counting down ,doors lock alarm armed all that buttttttt still have some more figuring out to do cause during start up i am getting a check engine light been set for error faulty communication from PCM to INSTRUMENT CUSTER so still sorting that part out ,only which my COBBS AP COULD DELETE THAT CODE TOTALLY FROM VEHICLE SYSTEM ,BUTTTTTTT ,i guess i will have to ask COBBS if that is even possible to do.
