You'd be believing wrong, it changed in 06 with the new drive by wire VVT engine and larger brakes.-I believe the ’07 Mz6 is the 4sp auto (same as the ’06-’07 Mz5), not the revised 5 sp auto used in the ’08 and up Mz5.
You should have gotten gallons then, and the preferred customer membership pays for itself with just that purchase. And I know it's the bees knees, it also lasts longer and performs better so when cost/mile is less, it is actually the cheap alternative.-Agree Amsoil is the bees knees but we are a frugal bunch. Come’on, we drive Mz5 and not decked out Oddys/Siennas and are always looking for cheap alternatives. I did use Amsoil in my flush and it was almost $100 for 8 bottles…
You really just wanted to say all that, which is pretty much what I wrote. The TLDR version is drive slowly until it's fully warm because it warms up more quickly this way. (also consider the wheel bearings, CV grease, fuel pump, power steering which need to heat up as well)-Not sure if you are aware but idling your car warms up the engine temp first and foremost, everything else is a byproduct and takes longer. Think about what goes on and how things get warm...
Evidence of what exactly? Oil analysis tells you if it's in the proper spec of viscosity and only partial contents. It'd be more useful to tell you when to change the fluid.Back to Mz5 OE transmission fluid. I wish someone (must be the original owner) would send a sample of the OE fluid to Blackstone labs for an oil analysis. This would give us the scientific evidence we need...
