Mazda OEM Parts OES Supplier?
Hello!
Does anyone know who makes many of the parts for Mazda OEM?
Are they manufactured in house by Mazda Factories, or supplied by OES Companies like Denso, CTR, Delphi etc?
I am asking as I am looking to replace the balljoints and tie rods on my 2013 Mazda, and the local Dealerships in Calgary, Canada have exuberant prices for OEM Parts.
I am used to Toyota and their network of owned companies and suppliers where you can buy the exact same part without the Toyota Tax, like Denso Alternators, NGK/NSK O2 Sensors, 555 Suspension equipment etc. I do know the belt tensioner on the Mazda was made by INA as it was clearly stamped on the original part I replaced.
Any idea what they might be for the Ball Joints and Tie Rod Ends?
Thanks!
Have you tried RockAuto.com or are you specifically wanting OEM?
I often do use Rockauto, but what I was hoping for was to find the brand that mazda uses in their OEM Box Parts.
Like the Serpentine Belt Tensioner for Example. If you buy OEM From mazda, its actually a INA unit in a Mazda Box. You can get it from INA itself on rockauto for alot less.
Likewise, I was hoping to find who was the manufacture for the balljoins and tie rods for Mazda, to buy them for less.
Toyota which was what I mainly own has been pretty proliffic about this. Means you can often buy OEM Parts for alot less if you know what to look for.
Spark Plugs, Alternators, Oil and Air Filters amongst others are typically Denso.
Coil Packs, Wiring, and sensors are Split between NGK,NSK,Delphi and the likes
Suspension has been weaning, as lots are made in house these days, but it used to be 555, CTR often made Suspension Equipment for Toyota as a Supplier.
Like I recently replaced my Thermostat on my Lexus for a Denso Unit. It was the exact same, just with the toyota stamp very clearly grinded off. Not to mention, alot less.
I haven't been able to find an answer. And if I did, the forums posts were old and outdated. What helps is searching the part number + manufacturers and reading reviews.
I try to go OEM. I cross reference mazda partnumber with partsouq, amazon, rock auto, mazda Canada, and mazda USA. Then I go from there.
If I go non-OEM I try to see what warranty the part has if any.
Sometimes there is only 1 part available.
I find warranty easier to do with OEM Parts bought from Mazda.
Partsouq is cheaper but no warranty.
Amazon warranty was nightmare but parts came quick.
Rockauto is solid.
As for tie rods and ball joints ...
For inner tie rods I'm running OEM.
For outer tie rods I'm running Moog to try out and they are greasable.
The balljoint is sold as complete part of control arm. I'm on my second set of Beck/Arnley control arms in the front within 2 years. I would not recommend Beck/Arnley if I was buying again... but I drive on really gnarly roads. I haven't tried buying the individual balljoints that you press in.
Denso, NGK, Akebono, KYB are a few that come to mind.
The big stuff is made in-house: engine, transmission.
Not sure about tie rods.
Yeah I figured as much that the suppliers would be the Japanese usual.
Was just hoping to find someone who knew who made the tie rods specifically
I think the term you want is "Tier 1".
Yup, that's a better word for what I'm looking for.
Ws hoping to find the tier 1 responsible for making the OEM tie rod so I could buy it from them instead.
Kinda like buying Denso alternators instead of buying them from Toyota for double the price. Sorry for the Toyota analogy, just what I'm familiar with.
Rockauto is solid.
I did actually press in Mevotech Supreme Ball Joints, and so far so good. Which surprised me since they have traditionally been so-so with QA.
But I think I'm this application they were fine, and the ability to grease them and push dirt out is appreciated.
Would like to stick to OEM for this however.
It’s most likely a company you’ve never heard of, and even if you had, I can all but guarantee you they don’t sell direct to consumers. I used to work for a company called Aludyne - they make all sorts of suspension components. They may very well make the OE control arms for Mazda. I can say for certain that if you called their US sales office in Southfield Michigan and asked to purchase a replacement component, you’d end up being the butt of a few jokes in the office.
Lmfao fair enough.
Figured there was 10 companies that only sold B2B for every 1 that repackaged for consumer use. Seems like money left on the table, but with the logistics of it, hard to say.
Was worth a shot considering plenty of them do sell direct.
I was able to get a INA Serpentine Tensioner, which is the one supplied in the Mazda Branded box. It literally had the Mazda logo just shaved off. Similarly I was able to get a Denso Thermostat that clearly had the Toyota Logo just dremelled out. I've had similar luck with CTR, ZF, TRW, Delphi, 555 and a few others.
But yeah it seems far fewer and in between with Mazda anyway.
Thanks for your reply!
If you don't mind me asking, what did you do at Aludyne? I'm studying mechanical engineering and I'm hoping to get a internship in the automotive industry within the next year or two. Would be cool to learn about your experiences in it.
Thank you!
I was a product engineer at a string of Tier 1 suppliers. The job is a lot of data and change management, and serving as a liaison between the (usually OEM) customer and the various internal technical and manufacturing groups. It was interesting work, but it’s pretty rare to keep the right fit at a job for more than a few years, thus my bouncing around. If you’re looking for long-term stability, the automotive industry probably isn’t for you. I’d probably still be at Aludyne if my wife hadn’t found her current job in Virginia, but I’m pretty happy to be in a more stable industry now.
I don't know the OEM suppliers for Mazda. But after replacing the lower control arms with OEM Mazda I went aftermarket with Sankei555 for the tie rod ends and radiator cap and CTR for front stabilizer bar bushings (which had the Mazda p/n and latest revision molded right in--- makes ya wonder) and rear stabilizer bar links. Also used Sunsong for brake hoses. The vendor "partsgeek" carries some CTR and Sankei. I'd use CTR control arms if they needed replacing again. Here's "partsgeek" for our ( mine's a 2014) cars (may need to scroll way down or do direct search). At $142-144 each it's reasonable after reading about poor fitment or reliability of other brands, Moog included.
Thanks! Yeah I kinda did narrow it down to CTR and 555. Unfortunately, CTR Tie rods looked great until I realized they do not have a hole for the cotter pin, as confirmed by a few others. They use a plastic locking nut if I am not mistaken.
The 555 however, do have one. That said, as far as lower ball joints are concerned Mazda uses a bolt to lock in place, and they all have it, some have a snap ring too.
So probably CTR LBJ for me and then 555 tie rods unless rock auto restocks 555 LBJs as well.
Yeah theres a solid chance CTR was the OEM for the Sway Bar Bushings. I mean according to them 30% of new cars use their parts.
Are you planning on replacing the ball joints only (they press in) or the control arm which comes with LBJ and new bushings. Can't imagine you would leave the old bushings in. Anyway, if doing the LCA, have you seen the threads detailing members experiences or should I say ordeals. You would be wise to do so unless you've done them before or you have a lift and shop tools. Removing the ball joint stud from the knuckle has posed some real problems and the front mounting bolt on the drivers side is not accessible straight on due to transmission case interference. And those bolts have a reasonably high torque value and have threadlocker applied. So a strong impact wrench would be suitable to loosen that bolt after some torque is lost due to extension and swivel socket. Or be a real hero and use a breaker bar( LOL).
d
I actually did do the passenger side ball joint as a emergency repair once with a Mevotech unit. Used a ball joint press and it all was done without a big impact.
I know have a big impact, but yeah was planning on just doing the ball joint as the bushings seem okay for now.
Probably wise too do it, but it's kind of pricy where I am and I'm a student on a budget.
But yeah I can see why it would be a pain.
Toyota bolt on LBJ were the easiest I've done so far. Aside from detaching the knuckle from it
Who makes the air filters for Mazda? Like for Toyota, they are made by Denso.
Just a bit of a update, for anyone looking in the end.
After doing the tie rods, balljoints and sway bar links with CTR parts.
(I chose them since they are a very big OEM)
But while doing it, I can see the factory tie rod end say "TRW" on the balljoints.
The lower balljoints, I would say are likely the same, and similarly the sway bar links, but I am not able to confirm as of now.
That said, the tie rods end do not look to be sold by TRW to the public. However the ones sold by 555 look to be the closest match, just unpainted which is a commonality for 555 aftermarket parts.
So for further reference I would go TRW, 555 or CTR on a personal account of the parts being high quality but certainly their own design.
