Original to Washington State 1991 Mazda B2600 LE-5 4x4 with locking hubs. Manual transmission extended cab. When I bought the truck it had a water leak. I fixed the leak, replaced the carpet and seats. Dry as a bone now and more comfortable to drive with the newer seats. Burns a little oil, otherwise no engine or transmission issues. Could use a set of tires, I only drive it 3 or 4 times a month and I believe the tires reflect that. I have all of the interior pieces parts as well. I found a set of heavy duty off-road bumpers that came off a 90's Toyota pickup that I planned on putting on the Mazda. The rear bumper fits but the front will need some modification. They can go with the Mazda if you would like them. They are solid steel and off-road worthy. This truck is by no means perfect, it has dents and dings and scratches. I bought a donor truck and replaced a couple of panels that were dented beyond repair. Also I found the leak to be coming from the driver door so I replaced it with the donor trucks door.
Known issues are heater motor not working, fuel gauge reads about half correct, steering wanders a little bit, power steering squeals sometimes, the tailpipe from the muffler is and has been missing and the rear opening window rattles. I just wedge a piece of rubber in it. All in all a solid truck that needs just a little more TLC.
Due to being limited to 20 MB, please message for more photos.
CLEAN TITLE
$3900 OBO
Thanks for the look.
1991 Mazda B2600i
VIN: JM2UF614XM0160067
condition: fair
cylinders: 4 cylinders
drive: 4wd
fuel: gas
odometer: 276,760
title status: CLEAN
transmission: manual
CLEAN TITLE
$3900 OBO
1991 Mazda B2600i
condition: fair
drive: 4wd
fuel: gas
odometer: 276,760
title status: CLEAN
