blackwolf1778
- mazdaspeed protege
so i recently have encountered a ton of CEL codes.... car is running like crap and idles rough some time as low as 300rpm... sometimes it tries to die all together but the choke catches it.. crazy stuff checked for vaccumm leaks infact im at 22 psi of vac. so nothing there.. anyhow im sure its one thing causing most the errors thanks in advance
in response to the missfire i changed the plugs with NGK copper and replaced that boot
P0171 - lean air/fuel bank 1 also says (cylinder number 1 denotes bank 1) (my wideband says at idle 13.2...)
P0140 - heated oxy sensor ho2s circuit no activity (is this the up stream or downstream?)
P0102 - MAF sensor low input signal
P0401 - EGR insufficient flow detected (needs cleaned im guessing?)
P0660 - IMCC actuator circuit malfunction (ive changed this damn sensor with a new one 2 months ago)
P0302 - Cylinder 2 misfire condition detected (def is missing)
P0300 - Cylinder random missfire detected
thats alot of crap... buying a new vehicle for a daily this week this damn car is always breaking lol
