StreetUnit
Banned
- 2003.5 MSP
Only 1 Available
Color: Silver
Part #: 69-6020TS
$229 shipped.
http://www.kandn.com/images/l/69-6020TS.jpg
Built for performance and show, the Typhoon Air Intake System is a free-flowing mandrel-bent aluminum tube induction system designed to fit many sport compact performance vehicles. Typhoon intakes come in one of three designs; cold air intakes (CA), short ram intakes (SR), or complete cold air (CCA) intakes which can be configured as either a cold air intake or a short ram intake. Some Typhoon's have high quality finish options including polished aluminum (part ends with TP), powder coated blue (part ends in TB), powder coated red (part ends in TR), and powder coated silver (ends in TS) among others. K&N intake systems replace your vehicle's restrictive factory air filter and air intake housing. K&N intakes are designed to dramatically reduce intake restriction allowing more air flow to your engine. More air means more usable power and acceleration throughout the engine's RPM range.
69-6020TS Product Specifications
Product Style: 69 Series Typhoon Kits
Estimated Horsepower Gain: 5 HP @ 3568 RPM
Color: Silver
Replacement Filter: RU-4950
System Type: Complete cold-air intake system
Base Outside Diameter: 6 in (152 mm)
CARB EO Number: D-269-24
CARB Exempt: Yes
Flange Inside Diameter: 2.5 in (64 mm)
Flange Length: 2 in (51 mm)
Flange Type: Centered
Footnote 1: Filter has molded-in velocity stack
Height: 5.5 in (140 mm)
Top Material/Finish: None
Top Outside Diameter: 5.5 in (140 mm)
Top Style: X-Stream
Weight: 9.3 lb (4.2 kg)
Product Box Length: 25 in (635 mm)
Product Box Width: 12.5 in (318 mm)
Product Box Height: 10.4 in (264 mm)
Color: Silver
Part #: 69-6020TS
$229 shipped.
Color: Silver
CARB Exempt: Yes
Top Style: X-Stream
