i want to know how to remove the bumper and the leather beside the shift knob!! Help!
Hi , i would like to know how i can remove the leather thing under the shifter...it is too long and i want to cut it , but dunno how to remove it!
PLUS
i want to know if you guys have a tutorial or something that can help me removing my front bumper. I want to replace the grill!
thanks for any help!
------> just received my skyline spoiler! i like it! :)
To remove the front bumper, start in the wheel wells. Remove almost all the plastic screws and rivets with a plastic phillips head screwdriver. This is so you don't strip the screws. Remove the brassy bolts on the wheel well with a 10 ? mm nut driver. There are some bolts/screws in the undercarriage plastic to be removed as well. There are 4 screw type bolts just to the side of the headlight housings that you have to stick your hand way up to get pointed up. There are 4 screws in the top grill pointed down to remove. There are 2 plastic rivets pointed towards you that I used a chemist's measuring spoon to pop out. Then pull the top grill up and out. You might need someone else to help you hold the bumper at this point as not to scratch the finish.
The wiring harness for the fog lights is on the passenger's side with ultra short wires. Careful with unhooking it. I broke a little piece off because it was below zero. Then reverse this process to put the bumper back on.
The bottom grill can be easily popped out with the bumper in place.
The whole process of putting the crappy AT grills on took more than a couple hours to manipulate, cut, and tie down, a couple weeks to rust out, and a couple minutes to snip off. Save the $50 and don't buy the AT grills. If you did, spray paint the hell out of them.
I hope this helps you out. You're on your own on the shift boot.
removing your shifter boot. first off open the door of your cup holder. grab each side by sticking your hands in the hole and gently pull back and up....the cup holder and the piece surrounding the shifter pops out. you will see TWO screws at the front of the shifter boot on its hold down ring. The kicker here is that there are two more but they are installed from the BOTTOM!!! (its things like this that makes me hate engineers) Here is where you get to make a choice. IF by lossening the two front ones and carefully removing the front part of the boot, IF you can get a stubby phillips head screw driver under there with a small hand you MAY be able to get the back two out. if not...what you need to do is completely remove the console. To do this, place the fingers of one hand in the slot that the emergency brake handle sticks through and gently pull. that piece pops out. on the floor in the resulting hole you will see TWO screws holding the console to the floor, at the front of the console on each side you will see a little button, that pops off and uncovers two more screws, THEN move both seats all the way forward and you will find two more screws on the sides of the console near the rear. NOW, unscrew the shifter knob. your console is now loose and can be lifted up and back to remove it. turn it over, remove the final two screws holding the shifter boot ring and its off. trim to fit the way you want...and reverse the previous steps to reinstall.
ugh....this bumper thing sounds like a pain in the ass....but I need to take mine off tomm to install a new grill and my DGM lip....
any more words of wisdom from those who have done this? and could I do this without removing the bumper? if so how?
BTW, i know how to get the top grill off, its just the lower grill and bumper that concern me
