How TO: CEL/MIL Eliminator!
acidbbg said:
I dont' think the MIL eliminator will work for you..sounds like you don't have your e6k wired properly..what's the code you are gettin?
How do you find out what code it gives you.
u will need to get ahold of an ODB II scan tool..i just go to Autozone..the let me uses theirs free of charge...
Chas
How big/small should the resistor and capacitor be, physical size wise? They have a couple of different ones there. I got the 1/4 watt resistor and the 35wvdc capacitor. They are real small and from what memory serves, they are the same size as the ones I put in my friends WRX. I'll take some pics later, my battery is dead.
Should be smaller than a cig in girth(width..and as small as your nail in lenght)!
Chas
Chas
Check out this pic. You can tell the size by comparing it to the staple in the package. I'm pretty sure the capacitor is correct, but the question is the resistor. The 1/2 watt one is a little bigger, like this size plus another half of it added on. What would happen if you put too small of one in there, would it do any damage? Zoom in if it isn't too clear of the size.
http://www.msprotege.com/members/Bigg Tim/DSC00463.jpg
looks right to me..it really shouldn't do any damage..if it's not done correctly..it can cause the ecu..to put out a CEL saying that the Sensor is Bad..but really the connection is not correct!
Chas
i have a quick question abt the o2 sensor........ which one is the signal wire (for my a/f guage) thanks
rob
rob
stolen from linux's how to:
http://www.msprotege.com/forum/showthread.php?t=14164
And here is the entire album:
http://photos.yahoo.com/bc/linuxrac...r+Shots&.view=t
To hook to the gauge itself, you will have to route through the firewall on the driver's side.
The A/F gauge itself usually has a positive (+) 12v wire, a ground (-), and the signal wire (that goes to pin #60). Find a suitable +12v source of ignition so that when you turn the ket to on, the gauge comes on. Anchor the ground (-) wire to chassis ground. In other words, find a screw going through the metal body of the car under the carpet under the driver's side kick panel, and ground it there with a loop anchor connector. The signal wire connection has already been discussed above. I hope all this helps!!<!-- / message --><!-- sig -->
This may be a dumb question but I just installed the Ractive header and it has a bung for the first O2 sensor (the one on the right hand side if I am correct). The other O2 sensor is on the left hand side which was after the precat, and there is no hole for that anymore. I have no place to put this sensor now. For now I put it by my Injen intake. Now Im not all that smart when it comes to wiring but...do I need to have this sensor pluged into the exhaust to use this CEL cheater??
Yeah dude, the O2 HAS to be in the exhaust. It is doing absoultly nothing in the intake. It measures the air fuel ratio in the exhaust that has come out of the motor and "tells" the ECU what it is so the ECU can then add or remove fuel to keep it in at the 14.7 AFR it likes in closed loop.
If you have the first O2 in the header, then put the second one behind the CAT. If you don't have a CAT, then remove it and use the MIL eleminator to keep the Check engine light from coming on. Chas may need to answer about not having the O2 in the system to use the MIL fix. I never had a header, so I don't know.
I just ggot a exhuast that removes both cats on my msp ans dosnt have a bunge for the o2 sensor. if i put the cel eliminator on and tuck the senors some where safe and wrap it up will it still throw a cel?
Bigg Tim said:
Chas--On which wire does the + side of the capcitor go to? I put it to the blue wire, is it right?
Yeah..that's right..the + side..ddin't matter when i installed it!
I had to do the same thing with the head i had on my car..a while ago..there was no bung hole for the 2nd o2 sensor..so i just wire tied it out of the way...and didn't get any CEL!
Chas
Chas
i wrapped my o2 sensor up in electrical tape, should i just leave it open in the air? cuz i threw a cel but the cel took ALOT LONGER to come on than having the o2 sensor not plugged in, does the o2 sensor need to be hot as well? or does the computer ONLY read o2?
I also have my O2 sensor wrapped up. I just zipped tied it to my intake so it does not rattle around.
Yeah..you can just leave it in the engine compartment...just zip tie it..so it won't fall/rattle!
Not sure about the heat..i basically zip tied it to where the male-female connectors are...Not sure why you are throwing a cel...you shouldn't keep the o2 sensor unplugged..it will def cause your car to run rich...very rich!
Also don't wrap entire o2 sensor up in electrical tape..it's not needed..(rlaugh)
Did you solder all connections?? If not you will throw another cel!
Chas
I have tried this 2 times now, and both times I threw a CEL. I know the last time the soddering is good so they are connected. I have my O2 wrapped up as well and ziptied to something in the car.
Would there be any other way to get rid of the CEL.
