ok so my protege had an engine with 92000 miles on it it was sputtering i changed spark plugs, o2 sensors, coil packs, checked all my vacuum lines than finally my engine started having valve ticking than one day boom goes the piston while on the highway. so i put in a engine with 65000 miles on it used my new plug o2 sensors, coil packs, and had to use the pipe that goes from the exhaust manifold to the egr valve on the newer engine from my old one and well i start it up and getting sputtering again. can anyone give me an idea on what i need to do i cant find the problem
