so im running ksport coilovers. ever since ive installed them my car has ridiculous amounts of bodyroll. am i supposed to change my endlinks and other suspension parts? its pretty weird because when i put back on stock tokicos the car feels normal. help!!
do those have adjustable damping? unless the end links aren't installed properly, you shouldn't notice more roll than you did before...it should be the opposite...
does the car bounce a lot now? or is it just body roll while cornering...start by selecting a stiffer damper setting if you can, although i'm not familiar with Ksports...
I just installed Tein SS coil overs about a month ago...and on the stiffest setting...seems like the car doesn't even have a suspension...let alone any body roll...its flatter than flat, but jumps rail road tracks and stuff...
yes they are 5 clicks from stiffest setting. height all the way down. spring one turn past hand tight. -1.5 camber all around. the car bounces bad all the time and i notice the roll while autocrossing/similar driving
