Greddy Full Auto Turbo Timer Installed
Ryan
03 Spicy Orange MSP
I finally got around to installing my greddy full auto turbo timer today, works great here are a few pictures
better picture of my guage cluster
there is a meet this sunday in maryland man. one im setting up at columbia mall check pages 6 and 7 of md, cant get no love thread
everythign is completely installed and working all three wires under the console the ebrake and the speed wire that hooks into the ecu man what a pain in the tail getting the ecu out. but hey everything on the tt works perfect. the speed wire needs to be spliced into pin 58 its green and orange for those that dont know. I'll try to do a writeup for it sense no one really has a writeup on the greddy full auto turbo timer. anyways. Also there are these things you can get at walmart that make it really easy instead of sodering the wires it scalled a line tap u can pick them up at any walmart in automotive section its a lil clip that goes over the wire that you wanan tap into and then there is another thing that slips over the wire to connect it to the line tap. Very simple and worked perfect.
congrats mine will be in soon, i think im goann put it where u put yours.. would my BC fit next to that? i think its the same width... hmm
im buying a greddy profec b black too i am putting mine next to it also ;) that'll be my next mod.
were did you buy ur profec b from? and how much was it?
explain what you mean the timer is setup on a harness that plugs into the tt.
pop the lil thing were the ebrake is off, then u'll see two screws towards the front, there is a big square opening now look at the console on the driver sside if you put ur finger up under the edge u can slide the wire up the console and right to that opening may have to stick ur hadn int he opening to feel for the wire but once it there splice the brake wire and u can neatly tuck the rest of the wire under the driverside of the console. :)
er...im having a bit of trouble understanding what you are saying...
there is a wire by the e-brake, after you take off the cover. and then there is a wire on the driver side? i dont get it.
thanks
LOL, okay ur greddy turbo timer comes with two extra wires on runs to pin 58 on the ecu the other is the e-brake wire, the ebrake wire is the one your run up the console (on driverside) and splice into the ebrake wire.
