This will be my last post on this thread, a kind of conclusion.
The gas mileage is somewhat acceptable. Around town, I am seeing mid-20s and on the interstate, upper 20s.
Around town gas mileage appears to be influenced heavily by the length of the drive. My normal commute is 2.5 miles (small town by many standards). While the engine warms quickly, the transmission does not want to shift in to overdrive until the temperature is above 170F, and the mileage remains in the low-20s. Once the car has warmed and on a longer drive around town, the mileage creeps into the mid-20s.
Highway mileage appears to be affected by the temperature as well. In the earlier posts, the car was barely breaking 20 mpg. Now, the car is seeing upper-20s. The only major difference is the change in the weather.
I never found a significant problem with the engine. The only changes made were new plugs, throttle position sensor, front O2 sensor and a new intake tube. The EGR was cleaned.
I normally run E10 and have done so for many years on many different vehicles. I expect there was an exagerrated effect of the ethanol in the winter mix. Ethanol vaporizes poorly at low temperatures and the refinery may have added more volatiles to the winter mix to improve starting. With the warmer temperatures this spring, the mix is moving towards the summer mix, which is better for gas mileage.
I have plans to improve the fuel economy but those come under the heading of 'mods' and will be reported separately from this thread. In the interest of more immediate gas mileage gains, I will increase the tire pressure from 32 psig to something higher.
Pretty pathetic that the P5 struggles to get better fuel economy than our CRV. But I still prefer my P5 for everyday driving!
