Front Wheel Bearing
ogsp5
225 whp @ 8psi
2002 p5 (MSP Powered)
My wife has a 05 6i. 5sp with about 70K miles. We just replaced the right front bearing and that rubbing sound is back. Does anyone know if there is a problem with the front bearings or suspension on the 6i
Could be your brakes possibly.. Or if the shield around your brakes got bent and is rubbing against it. Check the little things first before you replace parts that you might not have too.
The bearing that got replaced was shot. When it was removed it came out in pieces.
