Hey, MP3_moran, is that a CF hood? Is it gold mesh?mp3_moran said:As far as engine swap possibilities are concerned, I've been thining that the new 4 out of the mazda six would be a good option (other than trying to squeeze in the six cylinder).
thanks, ill do thatchdesign said:Ask for a good link in the probetalk forums i'm sure they have a good one post it in the 1st gen section and you shoudl get a responce.
Yes, it would be a "front end" replacement. You'd also need (unless you chose to replace it, which I would) the radiator. All powertrain components would need to be changed. However with an engine replacement, it's the perfect time to upgrade. The first change I would make would be the quaiffe LS or locking differential, good motor mounts, aluminum radiator, more powerful fuel pump, and replacement of the lower transverse beam. Hey, if the motor's out, the work is easy!PhyschoMP3 said:How much money would a turbocharged stock FE3 Engine cost and how much time would it take to put into an MP3. Wouldnt you need a new tranny also?
