Good post, welcome to the board!P_Diddy81_99 said:Here is a LINK that gives all the specs for the FE3. Also as far as the 2.3 KJ Miller Cycle, it has almost the same power output as the KLZE, but they're rare and expensive. The ZE would be a lot less hassle, cheaper, easier to install, also there's not much mod potential in the KJ, whereas you can still mod a fair bit of power out of the KLZE, so I'd say it's the better choice by far. Also the KJ only came with auto's, so you might run into trouble with the ecu if you drop it in a manual. Also with the KJ you will probably have to do something different with the hood, because the intake manifold sits higher. If you want to go for max power I would say go with the ZE and twin turbo it good for about 400 hp.
Just my 2 cents
