Difference in Rear Motor mount Automatic VS Manual
White_2002.5
2002.5 Mazda Protege5
Is there a difference between the automatic motor mount and the one for the manual. I recently ordered a motormount for the rear for a 5 speed and appears they sent me one for an automatic. If i just cut the bracket on it that holds some cable or something will it work the same? These are like OEM style. Thanks In advance!
Pix!
It may be the wrong one for our car. The only difference between auto and manual should be the durometer (auto get softer).
Did you get stock or aftermarket?
Here is the one I received. I ordered it before I got a good look at the rear of the motor. Now I have the entire head removed so i can see it very well. As you can see it says its for a Manual.. but looks like it is for an automatic. If the automatic is softer does that mean it will just rip and be worthless?
Unfortunately the old mount is still in the car. I have not been able to loosen all of the nuts on it yet. I have 1/3 done. LoL..
