2016~2023 CX-9 Stock Wheel fitment numbers?
RonK
2021 CX-9 GT
I'm going nuts over the way this manual is constructed. Every time I use the Appendix to find something like Navigation, there is simply no Alphabetic category in the back(Index) of the manual. I wouldn't normally be a pest so much but for the life of me, I simply cannot find any subcategory about WHEELS. Anyone know the fitment numbers for a 2021 CX-9 GT. I know they're 20" 255 50R20 104V for the tires. But what is the off-set? Thanks in advance,
No Specifications in this manual?? I know it's called "Owner's" Manual but for cryin' out loud, is changing the wheels and tires a "service center ONLY" job?
Try looking for aftermarket wheels on TireRack and they should have the specs that you are looking for.
I have already. They're too much and their selection is limited. I'm looking at Wheel Pros and they need an OFFSET. I should mention that I'm looking for winter-season wheels so they don't need to be pretty.
Would 18's have the same offset? I also would like to get a set of winter wheels.
Technically yes, as long as it has same width otherwise use an online wheel calculator to check for discrepancies.
I went with 18" tires and wheels for winter
I find a set of winter tires which is 235/65R18 with offset 40. The tire size and PCD, and Hub bore are perfect. However I don't know if the offset 40 is ok for my 2022 CX-9 GT, anyone has experience about 18'' tires offset? Thanks!
Feedback: 235/65R18 with offset 40, rim 7J*18, work perfectly with my car. BTW, this web is very helpful to change tire or rim: www.wheel-size.com
Generally, you do not want offset to be more than +-2mm. Some sources state a max. of +-5mm.
While the wheels and tires you describe will fit with no issues, I would suggest to stay in the range of 43-47mm, 8" wide wheel.
While the offset is pushing it, it's still acceptable. While it fits no problem, 235 is a bit large for a 7" wheel.
The set will work, but it's not ideal.
Thanks for your advice. Yes, it's closer to the brake and disc, and 7 rim is a little narrow for 235 tire. I brought this set of tires from market place from a owner of 2022 Pathfinder, and I didn't have much choices becasue the specs of cx-9's tire is too big to find a perfect one.
The specs are huge!
