2016~2023 CX-9 Stock Wheel fitment numbers?
RonK
2021 CX-9 GT
I'm going nuts over the way this manual is constructed. Every time I use the Appendix to find something like Navigation, there is simply no Alphabetic category in the back(Index) of the manual. I wouldn't normally be a pest so much but for the life of me, I simply cannot find any subcategory about WHEELS. Anyone know the fitment numbers for a 2021 CX-9 GT. I know they're 20" 255 50R20 104V for the tires. But what is the off-set? Thanks in advance,
No Specifications in this manual?? I know it's called "Owner's" Manual but for cryin' out loud, is changing the wheels and tires a "service center ONLY" job?
Try looking for aftermarket wheels on TireRack and they should have the specs that you are looking for.
I have already. They're too much and their selection is limited. I'm looking at Wheel Pros and they need an OFFSET. I should mention that I'm looking for winter-season wheels so they don't need to be pretty.
Would 18's have the same offset? I also would like to get a set of winter wheels.
Technically yes, as long as it has same width otherwise use an online wheel calculator to check for discrepancies.
I went with 18" tires and wheels for winter
