CP-E Turboback system installed *with sound clip*
Armyguy1104
06 MS6 GT
I decided to go ahead and purchase/install the CP-E downpipe and catback system this past thursday/ friday. The guys at CP-E were great and extremely customer friendly, as has already been mentioned several times here. The only bad part was waiting for 6 hours at Extreme Motorsports while it was being installed, but those guys were great to and stayed till the job was finished even though it was a friday night. I had the magnaflow exhaust before so I will include the sound clip of that as well for comparison. I do have one problem that someone may be able to help me out with, when I put the magnaflow system on they removed the tips from the bumper since the mf tips needed to fit through. Anyone know where I can get a pair (not through MazdaUSA) for cheap. Anyhow without further delay here are the sound clips.
Magnaflow Catback
http://www.msprotege.com/members/Armyguy1104/1st run.WAV
CP-E Turboback Exhaust
http://www.msprotege.com/members/Armyguy1104/CP-e Exhaust.WAV
Also to add on, if you are having the same issues as a lot of us are with smoke coming from the tail pipe it does become much more noticeable with this system. Through no fault of CP-E though, its quite possible the high flow cats allow more smoke to pass through, Im waiting to see what the dealership is going to do about it, and since I had it in the shop two times prior to have the DP installed I shouldnt have a problem with them telling me thats whats causing it or voiding the warranty for that problem.
Armyguy1104 said:
....and since I had it in the shop two times prior to have the DP installed I shouldnt have a problem with them telling me thats whats causing it or voiding the warranty for that problem.
sounds like you might be rollin the dice on this one...
