I'm redoing my suspension soon, and I just noticed that the rear sway bar brackets are not flat, but mount on a 90 degree angle. I know I can get adapters that allow the use of flat brackets, but they don't allow for a greasable bracket. The way the adapters mount the brackets leaves not enough clearance between the track bar to clear the grease zerk. Has anyone been able to simply bend the tabs on aftermarket brackets in order to fit the stock bolt holes?
