BC Racing Rear Camber Plates!
What is the need for camber plates in our cars? Unless you're following to super retarded super camber fad like all the civics are going for...
Man this is super old! Just an FYI, the K-sport rear camber plates work with BC coilovers
The plates allow you to adjust camber from the top of the strut instead of at the strut mount (BC's are slotted which allow up to -2 degrees of camber). The top camber adjustment is beneficial for both functional and form-based wheel fitment, as it allows you to run wider wheels without out having to worry about the inner barrel hitting the strut from camber.
