Axle Removal
Not sure if this is the right place for this but I need to get the axles out of a donor car I have for a transmission swap and am having some trouble with the 32 mm hub bolt. I have looked at the shop manuals and stuff but just wondering if any one can point me in the right direction that has done this before.
i just got my driver side axle nut off.. its a pain the but.. you have to un-pop the lock on the axle nut.. its an indetation on the axle end.. you'll see what i mean.. remove the lower ball joint from the spindle, and carefully remove the axle from the steering knunckle.. then from the trans. .. passenger should be the same except you have to separate the half shaft from the drive shaft. usually with a bar and a few taps with a hammer.
