Are there any guides on the HKS type 1 installation?
ebrake, remove the cover. there is a wire there. tap into that.
speed wire, freak the ecu, just go to the rpm signal in the back of the guage cluster.
and also, how many times do i actually need to solder connections? just for the actual regular wiring right, not the ebrake and stuff?
okay, the ebrake cover just pops off like AFaceinthecrowd said, its a purple wire, tap into that for ebrake. for the speedo and RPM (yes you need both), tap into the gauge cluster, its alot easier. the wire colors are listed in the car audio/electronics section. I only soldered the main wires and used wire taps for the other wires, but my spedo and/or RPM wire are coming loose, so i am just going to solder those in too.
