Alternator Help
Timmy_03-P5
2003 Mazda Protege 5
Hey everyone, last August I replaced my timing belt and alternator (and like everything else) but while taking off the old alternator, the impact slipped off the bottom bolt and it got the socket stuck on the head. So when I put it back in, it stripped the head to no end. Well it's been fine until I checked the other day and the alternator can wiggle back and forth...So I'm wondering what size that bottom bolt is so that I can replace it and make sure the alternator is tight.
tl;dr: stripped the head on the bottom bolt for the alternator, wondering what size it is so I can replace it.
thanks for any help.
Go to a dealer and order the bolt you need. Probably not more than $10 and no headaches.
Can i get a wiring diagram b/c i have this little small square connection thats just hanging .. my ground is connected and the connector is too. but theres this small connection that has a green cable and i dont know where its supposed to connect. Help!
(nailbyt)
