GhostMercury
- MazdaSpeed 3 08.5
well i made a build list here and i realized THATS TO MUCH MONEY...
so i wana see what i can do with a lower cost
well for the TURBO i wana keep the stock setup for now until i decide to throw more money away on my lovely msp lol
ima start with a FMIC with relocated MAF and hks ssqv $idk cause its gona be custom
then get a DSM AFC II $300 sumthin
then work on the block..this is where i need help deciding on what to get
Arias Piston and Pauter Rod Combo $1,299.95
ARP Head Stud Kit $115.95
AWR Deep Sump Baffled Oil Pan $349.99
Complete Bearing Set $239.95
Complete Engine Gasket Set $229.95
now what compression should i go with?
and how much boost can i get up to without working on timing? cause i wana just stick with the AFC
also when will i need bigger injectors?
as for cooling..will i need any other cooling additions like radiator and fans?
if there is anything else you would like to add go ahead
