1/4 mile times with slip
I've had the car for 8 days now and wanted to see what I could do with it. My 2nd run yielded a 14.062 at 99.77 mph. The car is completely stock with 10,8XX miles on it.
Holy wheel hop!
I love this car.
I kept trying to clean off/warm up the tires with the DSC on, stalled it one time... that was embarassing. I always forget about the DSC.
Post your time slip and I'll add you to the list
Okay here's mine. Car# 2138 racing against another speed3
My scanner was acting up, so I ended up scanning it upside down and flipping it to get the portion I needed, it kept cutting it off, so please excuse the sloppiness. There were with some all season Potenzas, as well.
2.253, 9.191 @ 81.05, 14.062 @ 99.77, (stock), ~150ft
Wow! That's a excellent time especially for 100%stock.
Please post time in the following format:
SN - 60ft, 1/8th(et and mph), 1/4, (et and mph) (Mods)ASL (feet above sea level)
Here is mine for example: MS3077- 2.07, 9.03@ 80.17, 13.97@ 99.92 (I/MM)
Is it just the last 4 digits of the SN that you want? If so, above post is fixed.
I was extremely shocked when I saw 14.062 on the slip, I was not expecting that.
4thStroke- 2.253, 9.191 @ 81.05, 14.062 @ 99.77, (stock)
*Added to list
Tried to send slip and pic of car on opening day. failed maybe too high res ? 4/20/08 nyirp 3:16 pm right lane #158 r/t .683 60ft 2.319 330 6.021 1/8 9.007 mph 82.75 1000 11.561 1/4 13.749 mph 101.83. She is untuned and runs like poop. I was surprised. nitto's next week should help 60 but have fuel and boost issues half throttle is all I can use. Ps any suggestions about pictures not being received? Maybe I will try to scan time slip
I would suggest scanning your slip if you can; comes out much clearer. I just went to a Fedex/kinkos because I don't have a scanner at home.
Thanks
I am trying the correct pixel with the jpg on the kodak easy share v1003. Ihave a scanner but I cannot figure out howto use it either. it sucks getting old and senile. I will do as suggested thanks
favor please
Could you pm me and i will give you my email address say hello and then I can send the picture to you of slip. I want to play by the rules But that is the only way I know how to get this to you
New and improved time with some help! Delrin TRZ ftw.
StewRat - 2.233, 8.946 @ ?, 13.740 @ 102.55 (I, MM) 1492ASL
Tires?
We have same time but you have more speed.the secret is the 60? nice. Any pointers for the rookie!
*added to list*
ericrapp- 2.319, 9.00@82.75, 13.74@ 101.85 What are you mods?
Thanks for all your help 077. and patience. The nittos and a bit lighter wheels should be here thursday. test and tune Friday eve. Maybe i can cut that 60ft down. and reduce the silly wheelspin.
putin up my slip dis week brothers got camera. gotta 13.5@103 2.2 60ft mods (cai,tbe,tmic w/tubes,bov,mm) good times 4ur mods guys keep it up
Yeah I bet you'll be around 13.4-13.5ish with a better 60ft (2.0-2.1) once you get your new rubber & wheels.
What were you MODS when you ran the 13.74? I need this to add you to the list.
Ive heard the reason I was faster but with the same time is due to wheel spin. On that run I took it to 2500 and very quickly let out the clutch a hair after the last yellow. But then what, I'm still a rookie too, I think I've made around 13 passes in my life.
