1/4 mile times with slip
MS3077
Banned
Mazda, Mazdaspeed 3 GT
Mods can you please make this a sticky?
Rules, no bulls*** talking, simply post your time with a link to the timeslip and list your mods. With proof of timeslip you will be added to the list.
Use these abbriviations for mods:
I = Intake
IN - 3in Turbo Inlet
DP = Downpipe
CBE = Cat Back Exhaust
MP = Midpipe
TBE = turbo back exhaust
CDFP = cam driven fuel pump upgrade
EMS = tuned
MBC = boost controller (specify spike and hold) ie: 18s15h
UI = Upgraded Intercooler
MM = upgraded motor mount
S = suspension such as springs coilover
T = turbo upgrade
W = Weight Reduction (spare and jack does not count)
DR = Drag Radials
SL = Slicks
Please post time in the following format:
SN - 60ft, 1/8th(et and mph), 1/4, (et and mph) (Mods)ASL (feet above sea level)
Here are the time frames
12 second club:
Driver311 - 1.83, 8.19 @ 86.52, 12.79@106.9 (I/MP/18psi/SL) 2700ASL
tru-boost - 1.90, 8.28@ 86.36, 12.82@107.90 (I/TBE/manifold/T/CDFP/MM/
MBC 19psi/SL)
Laloosh - 2.01, 8.46@ 87.69, 12.90@111.14 (I/TBE/18psi/CDFP/S/MM) 320ASL
13 Second Club:
FMOS Racing - 1.858, 8.415@84.07, 13.080@107.55, (I, MM, DR), 750' ASL.
SharkDiver 2.01/8.63@82.87..13.31@105.35. (MM,FMIC,DP,MP,cobb sri,Cobb AP,stock tires)
sleeper3 - 2.234, 8.742 @ 84.18, 13.365 @ 106.75 (I/IN/IC/MM)
SLS MS3 - 2.06, 8.69@83.54, 13.39@104.33 (I,DBE)
Russum - 2.15, 8.89@ 83.41, 13.63@105.48 (I,CBE)
FMOS Racing - 2.14, 8.95 @82.56, 13.68@106.67 (I)
aaronc7 - 2.44, 9.11@83.74, 13.71@106.91 (I/TBE/FMIC/MM/EMS) SL
Blacksheepms3 - 2.188, 8.89 @ 82.0, 13.73@101.26 (I/TBE/MM/S)
StewRat - 2.23, 8.946@ xx.xx, 13.74@102.55 (I,MM) 1492ASL
ericrapp- 2.31, 9.00@82.75, 13.74@101.85 (I/UI/TBE/MM)
lantagne21 - 2.22, 9.03 @ 82.25, 13.77 @ 103.95 (I, FMIC, DP, RP, MM, S)
Focused - 2.31, 9.10@81.84, 13.80@102.67 (I/MM)
Jarod7920 - 2.13 9.034@79.93 13.91@100.70 Stock!
Daytripper79 - 2.23, 9.12@80.89, 13.93@98.61 (I,MM)
TRU-BOOST - 2.21, 9.07@81.12, 13.94@101.77 (I/MM)
MS3077- 2.07, 9.03@80.17, 13.97@99.92 (I/MM)
14 Second Club:
JDMspeed3 2.353, 9.203 @ 81.74, 14.001 @102.38
clos561 - 2.28, 9.14@79.9, 14.03@100.26 (I)
Jesse MS3GT - 2.27, 9.15@78.58mph, 14.05@99.40 , (I/MM)
4thStroke- 2.25, 9.19 @ 81.05, 14.062 @ 99.77
jam_asian85 - 2.30, 9.20 @ 79.94, 14.09@99.43 (I,DP,MP,MM)
07MS3GT - 2.254, 9.144 @ 80.50, 14.090 @ 97.68 (stock, 28psi front/ 40 rear) 669ASL
jtspells- 2.39, 9.31 @ 80.63, 14.16 @ 102.19
ill_eagle94 - 2.39, 9.361@79.27, 14.19@102.16 (I/DP/MP/MM)
RonTonkinMazda - 2.43,9.466@82.95, 14.20@104.38(I/IN/IC/MP/CBE/20psi)
MidwestSpeed3 - 2.304, 9.349@78.05, 14.27@100.17 (I/MM)
zim - 2.41, 9.46@79.54, 14.32@102.23 (MM)
builthatch - 2.35, 9.43@78.58, 14.33@101.01(I,MM,MP)
Cookim6 - 2.35, 9.50@77.98 14.43@99.22, (MM)
Babyface13 - 2.36, 9.50@76.89, 14.47@99.71
JDMspeed3 - 2.467, 9.686@77.63 14.682@101.34 (I)
Zimmer - 2.292, 9.634@76.97 14.717@99.28 (I)
silversurfer3 - 2.43, 9.65@76.44, 14.79@96.89 (I/CBE) 2000ASL
Once you post your time in the correct format with a link to the time slip you will be added to the list
Okay so it looks like I will be taking this over from laloosh so please follow the rules.
Now as far as no bulls*** talking you can get into detail about your run in stuff this is fine, like who you went up against, driving technique, etc. Just be honest and try to keep it short and to the point.
Track is still closed here and it was sold in January. Drove past yesterday and the place is barren. This is the only 1/4 for a long ways. This could ruin a summer. Ran 14.02 with mscai last summer but cannot find slips mostly mid 14s without driver mod.
New Best time! 13.97@ 99.92 (rockon)
MS3077- 2.07, 9.03@ 80.17, 13.97@ 99.92 (I/MM)
I will not post on offical list until I scan my time slip.
At 5800 feet altitude into a 25mph headwind on a slick track: 14.94@92.89 with a 2.388 60'
Not posting the slip as I'm the slowest on the list. Who wouldn't believe me.
Altitude ftl
Altitude ftl
Seems like a pretty good time for being so high up.
Are there so sort of correction factors for things like this?
(scratch)What rpm's were you shifting at? WOT shifts? Tire pressure? DSC on or off?
Congrats on finally getting into the 13's! (dance)
Thanks!
Tire PSI: front- 29.5 rear- 32
Launch: 2500rpms quick slip of clutch while modulationg throttle.
DSC: OFF
Shifting @ 5600-5800rpms 1st - 5th
Nothing fancy, just fast shifting. I do have the TWM SS and bushings installed so that might have helped some I suppose.
StewRat - 2.192, 9.107 @ 79.46, 13.968 @ 100.43 (I) 1492ASL
I've had the car for 8 days now and wanted to see what I could do with it. My 2nd run yielded a 14.062 at 99.77 mph. The car is completely stock with 10,8XX miles on it.
Holy wheel hop!
I love this car.
I kept trying to clean off/warm up the tires with the DSC on, stalled it one time... that was embarassing. I always forget about the DSC.
