Your opinion on Konig Unkowns?
The second set (the ones in Pburg) are nice. +40 with no suspension mods should work, for some reason I thought the off set on those was +35. Haha! Pburg is not too far from you, go ahead and run over there and try them on. Make sure to drive with the wheels on so that the suspension can settle. I am running +42 offset without an issue (Iam slightly lower than stock 1/2"-3/4") so what would another 2mm do? Oh ya I googled the first set and it is possible that they could be a 5x100/5x115 bolt pattern, they are also +40 offset. I think the first set is a better deal if the tires are good. Does the other set come with tires? I will do more research!
Okay, now what I have found about these wheels is this: Motegi mr4 is a 17x7+40 5x100/5x114.3 @25.5lbs
Eagle alloy series193 is 17x7+40 5x100/5x115 or 5x100/5x114.3 @21lbs. I did not see any other offsets available, but that doesn't mean they were not made.
Now the only other issue that may arrise is the hub bore, I could not find that in my search.
Well we tried them on. they fit good! I bought them for 360, and i got the tuner lugs
Wow! Thanks a ton! I am going to try and chew him down a bit since they have shot tires, im going to offer him 300$ Hopefully he bites.
