xDJ DUBx's 03.5 Pure White LX-T
get a bottle of windex or soapy water and spray it on all vac lines, while your there, might as well clean the engine bay. lol
I have a boost/vac gauge. when you mean higher, do you mean like -25 or -15? lol. The negative part makes it confusing to how you mean higher.
mathematically above -21... so if the most vac you read is -15, you have a leak.
Y wouldn't this work for a vac leak? I've watched people do it b4...
because it would just get sucked into the IM... you wouldn't see the bubbles or anything like if the air were pushing out.
when you hit fuel cut, youll know. only happens to me in the rain when the maf gets wet
I know that -15 is higher than -21 but I didn't know if carl was being mathematically correct or not.
OK so I'm kinda oblivious to the way of the turbo but I have a question? Irealize its not specific to turbo but it always comes up with the MSP
What is the purpose of fuel cut and why does it happen. I get it limits what the engine can do as a "safety" precaution (i think) but would fuel cut go something like this fuel cut-->less fuel-->lean afr-->hotter combustion temps--> hotter engine-->s*** goes boom.
Or am I missing something?
its a protection mechanism, the car doesn't believe it has enough fuel delivery capacity to keep up with the amount of air being forced in, so it shuts off combustion all together.
