Yezzer. Pretty simple, feed from the plate, return to the pan.
Just did the math and all that again and calculated in every single thing that needs to be done to install the turbo, and I will have all parts ready to go by 10/16 guaranteed
Just did the math and all that again and calculated in every single thing that needs to be done to install the turbo, and I will have all parts ready to ship to xJAZx by 10/16 guaranteed
Ok, so as most of you know, I've blown the spark plug in cylinder 4 twice already over the past 3 months. I was pretty sure it was the coil pack, so yesterday I swapped my coil pack out with the p5's. I only took the second one, not both.
Today I make my short drive to work and its randomly missing a lot. Before on mine it didn't really do it unless I was WOT.
swap the other coil into the same location? if you changed the part and it changed the reaction.. I still say thats the failure point... try swapping the wires while you're at it too?
